Results 1 to 10 of 16
Thread: Cannot see Objects as I move or rotate them
    100 Club chrisr's Avatar
    2005-01
    Ballina,Ireland
    142
    Talking Cannot see Objects as I move or rotate them
    When I move or rotate an object, I can not see it. But when I move a dimension I can see it, so its not 'DRAGMODE'.
    Does anyone know how to fix this.
    I could stop if I wanted to jgratton's Avatar
    2002-07
    Calgary, Canada
    397
    Default Re: Cannot see Objects as I move or rotate them
    What version are you using? I noticed 2006 works differently.
    13,657
    Question Re: Cannot see Objects as I move or rotate them
    Quote Originally Posted by chrisr
    Hi
    What Layer are the Objects on ?
    Dragmode not working
    Have a good one, Mike
    2005-01
    Ballina,Ireland
    142
    Thumbs up Re: Cannot see Objects as I move or rotate them
    Using AutoCAD 2002 and the objects are on a named layer.
    2004-07
    Detroit Michigan
    2,508
    I sometimes cannot see objects and I think it is a hardware issue.
    All computers tend to skip a beat every once in awhile.
    Im not running a slug bug either.
    Member Greywethr's Avatar
    2003-02
    Half-hour N. of Philly
    35
    I'm using ACAD 2007 and this has been bugging me for a few years. I switch between dragmode ON and dragmode Auto multiple times per day. Why, you ask? Because I manipulate objects in my drawing, and I also insert blocks.
    When dragmode is set to Auto, you can see block attached to your cursor as you're inserting it. However, if it is set to ON, you cannot see them. Unfortunately, when it is set to Auto, you often cannot move or copy an item a distance based on it's original location. Say you have a rectangle... no seriously, say it. You want to move that rectangle so the top-left corner is 4" to the right of where the bottom-right corner is now. You cannot, because as soon as you pick the base point, the rectangle moves with the cursor, and you cannot pick any of the points it used to inhabit because they're following your cursor. This doesn't always happen, so it drives me nuts.
    2015-11
    Jo'burg SA
    4,512
    Don't know what's going on ... on Vanilla 2008 I have DRAGMODE=Auto, block inserts & moves work fine (preview and possible to pick old object snaps). However with DRAGMODE=ON move does not "drag" the object, neither does Insert show the block. It's as if ON and OFF mean the same thing, so (as far as I can tell) here's the ADeschk speak:
    • ON = OFF
    • OFF = OFF
    • Auto = ON
    WTF? Fortunately in 2008 (it seems) leaving DRAGMODE set to Auto works for all instances (at least those I've come across).
    2015-11
    Jo'burg SA
    4,512
    Even weirder ... looking through the help (searched on drag keyword) came across copy with grip edit by holding Ctrl down.
    Now that was something I didn't know ... so I tried it, works great ! At least for the 1st copy , then the cursor starts jumping onto random points. As if snapping to an irregular grid, no objects behind (all layers on & thawed) - see screen captures ... should've made an AVI to show how the cross-hairs jump, but try it yourself. Maybe there's something wrong with mine?
    Cairo - no, not Illinois
    5,070
    Quote Originally Posted by irneb View Post
    • ON = OFF
    • OFF = OFF
    • Auto = ON
    Back in the bad old days of 80286 processors, tuning DRAG ON allowed you to type DRAG anytme you wanted to see the ghost image of the entity you were moving or inserting. With the processor capability back when, DRAG AUTO was kinda risky -- you might get stuck a long time waiting for a whole lot of redrawing going on, because it would automagically drag anything anytime dragging was possible..
    DRAG OFF was useful in scripts or LISP routines that moved objects around without spending time painting the screen.
    think of the varous settings today are pretty much legacy items, go with either OFF or AUTO depending on your inclinations
    2003-02
    35
    Lightbulb Re: Cannot see Objects as I move or rotate them
    That IS a handy li'l command, but I cannot find a way to specify the distance. What I do know, is that once you copy it once that way, it remembers the distance and will work like offset in any direction. Check it out.
  1. Quick rotate and / or move-rotate
    By Rroger_D in forum AutoLISP
    Last Post: 2015-08-13, 09:22 PM
  2. Move and Rotate 3D objects in Wireframe Environment
    Last Post: 2013-07-30, 10:44 PM
  3. rotate then move
    By chad.beussink in forum AutoLISP
    Last Post: 2008-08-22, 01:23 PM
  4. Move Objects but sometimes included Dimension Objects do not
    By moshira_hassan in forum AutoCAD General
    Last Post: 2006-11-10, 08:32 PM
  5. Can not see Objects as I Move them or Rotate them
    By hugvi76 in forum AutoCAD General
    Last Post: 2005-01-19, 10:04 PM
