Thread: Model Space Viewports
    I could stop if I wanted to Merlin's Avatar
    2004-05
    Brisbane, Australia
    395
    Question Model Space Viewports
    A curious one....I was asked recently about model space viewports...(which I completely forgot about after being taught about them YEARS ago)....Now before I go further, that's the viewports created in modelspace (not viewports showing modelspace from paperspace)
    The question was whether the view in one model space viewport could be rotated leaving others to their predetermined view....
    hmmm....
    cheers
    John Mc
    2001-03
    13,499
    Default Re: Model Space Viewports
    Hi
    Simple answer, yes.
    Have a good one, Mike
    2004-05
    Brisbane, Australia
    395
    Quote Originally Posted by Mike.Perry
    Hi
    Simple answer, yes.
    ....thanks!
    11
    Yes and I believe you can have a different UCS in each one. I am not sure but I have noticed that if I am in two modelspace viewports and I set the snapang to say 45 degrees in one, it is still 0 in the other. Of course, that is not the same as UCS.
    2003-06
    I use the DVIEW command.
    Make sure the viewport you want the objects to be rotated in is unlocked. Make the viewport active. Type DVIEW at the command line. Select the objects you want to rotate. Right click to accept. Type TW for twist. Enter the angle you want the objects rotated and hit ENTER. Right click to accept. Now set the scale and lock the viewport up. This does not affect the objects in model space at all.
  1. 2011: Model Space Viewports
    By Joshua Kohl in forum AutoCAD General
    Last Post: 2010-11-19, 07:18 PM
  2. How to include drawings in Model space into Viewports
    By dlauxx in forum AutoCAD Annotation
    Last Post: 2009-03-12, 02:03 AM
  3. Replies: 3
    Last Post: 2007-04-21, 05:38 AM
  4. viewports in model space
    By dzatto in forum ACA General
    Last Post: 2007-04-13, 09:00 PM
