Results 1 to 8 of 8
Thread: Convert Splines to Polylines
    Question Convert Splines to Polylines
    Hi everyone,
    I'm new to AUGI and I could really use your help. I'm doing graphic design with Autocad right now and I'm having a really hard time. I need to import Illustrator files to Autocad and have Polylines, NOT SPLINES. My drawings are sent to an engineer who works with Gibbs and it doesn't work with splines.
    I am a beginner with Autocad, so please explain step by step and don't hesitate to send my links or anything you can find...
    THANKS
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Convert Splines to Polylines
    Have a look at this tip from the AutoCAD Knowledge Base provided by Autodesk.
    ID: TS69659 - Convert a spline to a polyline for conversion to a third-party product
    Smile Re: Convert Splines to Polylines
    Thanks Opie,
    I guess I have an other problem, I can't try you tip because Autocad freezes within a minute of opening my Illustrator DWG. I don't know if the fact that I use Autocad 2000 has something to do with it.
    Does that happen to anyone else?
    2002-01
    jUSt Here (a lot)
    9,106
    I can't help you there, since I don't deal with Illustrator.
    Have you tried to Recover the drawing? (found in the File Menu -> Drawing Utilities) or Audit (also found in the same place)
    2001-12
    St. Louis
    5,410
    Talking Re: Convert Splines to Polylines
    julie, I'm going to move this from the Software forum to here, as I believe it will be served better. Thanks!
    Quote Originally Posted by juliefrancoeur
    Hi everyone,
    THANKS
    Melanie Stone
    @MistresDorkness
    Technical Editor
    13,656
    Hi
    Maybe also try the information found in the following thread...
    splines to polylines
    Have a good one, Mike
    Earth
    9,805
    THANKS
    You don't have to mess with lisp files or anything like that.
    Use WMFOUT to create a WMF file of the splines.[*]
    Erase the splines from the drawing
    Then use WMFIN to reimport the splines, except they will come in as polylines. Scale 2X and use upper left of viewport as insertion point.
    [*] You might even be able to import the WMF files into Illustrator and skip the second AutoCAD step.
    R.K. McSwain | CAD Panacea |
    100 Club Olaf.Banckaert's Avatar
    2006-02
    Belgium
    133
    Thanks Opie,
    Try to import it as a block and then save it in Acad. After saving do a purge and save again.
  1. Transforming Splines into Polylines
    By chgolombek in forum ACA General
    Last Post: 2007-11-20, 08:55 PM
  2. Converting splines to polylines?
    By matt.143284 in forum AutoCAD LT - General
    Last Post: 2007-08-31, 12:47 AM
  3. 3D Polylines and splines
    Last Post: 2007-01-16, 04:33 PM
  4. Replies: 2
    Last Post: 2006-05-18, 07:27 PM
  5. splines to polylines
    By tflaherty in forum AutoLISP
    Last Post: 2005-09-13, 09:10 PM
