Results 1 to 6 of 6
Thread: qsave = revert back
    100 Club sturner's Avatar
    2004-05
    Maryland (sigh)
    149
    Default qsave = revert back
    i looked and did not find this in my search. i have a user that when he selects the save icon map will revert back to a earler drawing state say 10 min. ago. this is not all the time maybe three times a week. he is not running any lisp or is it linked to a particular file, just a little weired.
    thanks
    -sean
    we are running XP, AutoCAD MAP 2004 SP2
    Civil Engineering Moderator MHultgren's Avatar
    Indy West (Not West Indies)
    1,447
    Default Re: qsave = revert back
    In his options, what does he have his Save Percent set to? For a full save, it should be set to 0.
    2004-05
    Maryland (sigh)
    149
    30
    this is not happening during a auto save but a manual full save.
    1,447
    Sean,
    I know the ISAVEPERCENT is only "supposed" to affect the incremental saves, but I have seen problems with doing a QSave or "full" save if the modifications to the original file are less than the ISAVEPERCENT variable. So, if you open a file that is say, 50 MB and make 5 MB of changes, you have your ISAVEPERCENT set to 30 ( 30% ) and 5MB is only 10% of the file, I have seen it save the file with the original objects. I always change this variable to 0 to eliminate this bug. Maybe they will have it fixed in the next SP.
    2001-05
    Austin, TX USA
    2,201
    Another nice thing about setting it to 0 is the file size gets smaller.
    2004-05
    Maryland (sigh)
    149
    thanks,
    i'll give it a try, it's weired never run across it before.
  1. Revert from Wiggle Pen back to CAD lines?
    By ROBinHI in forum Impression - General
    Last Post: 2022-10-19, 09:33 AM
  2. 2013 Inches Revert Back to 0.0 on Transforms
    By ben.bringardner in forum NavisWorks - General
    Last Post: 2013-01-18, 10:30 AM
  3. 2012: UPDATEFIELD command causes currentsheetset fields to revert back to ####
    By tstarkeyaz in forum AutoCAD Customization
    Last Post: 2012-12-18, 10:34 AM
  4. XREF layers revert back after closing dwg?
    By cadman33619 in forum AutoCAD Civil 3D - Survey
    Last Post: 2011-11-17, 01:55 PM
  5. Replies: 8
    Last Post: 2010-01-27, 02:10 PM
