Thread: Bitonal images
    2013-11
    Default Bitonal images
    Good day,
    Does anyone know why do the raster images that i insert becomes distorted when i convert them to bitonal?
    Have a nice day.
    Thank you
    Turlock, CA
    6,501
    Default Re: Bitonal images
    You didn't say what you are starting with. However, it has to do with the bit density of each pixel. For example, if you start out with a 256 bit image, the software has to determine how to convert 256 possibilities down to 2. There are several algorithms you can choose when doing this. Most of the time though, I find that it doesn't work going from one extreme to the other. What I do is down convert in steps. Convert 256 to 128, then 64, then 32, etc., etc.
    C:> ED WORKING....
    LinkedIn
    2014-01
    Huh, I hadn't thought of converting my images in steps like you mention. I'll have to give it a try.
    _____________________________________________________
    Turlock, CA
    6,501
    It takes longer, but you get consistently better results.
    C:> ED WORKING....
    LinkedIn
  1. Slide Shows of Images and Drawing Images
    By peter in forum Bridging the Gap: LISP -> .NET -> LISP
    Last Post: 2014-01-25, 08:12 AM
  2. 2012: Ghost Images and Lines On-Screen and in Exported Images
    By cwride in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-08-15, 08:49 PM
  3. Raster design bitonal image for contour follower
    By swyman in forum AutoCAD Map 3D - General
    Last Post: 2010-09-01, 03:30 PM
  4. convert to bitonal image
    By rschaff in forum Raster Design - General
    Last Post: 2010-08-03, 02:07 PM
  5. Convert to bitonal image
    By LanceMcHatton in forum Raster Design - General
    Last Post: 2006-04-27, 01:25 PM
