Thread: extract data from shapefile
    2004-06
    Slidell, Louisiana
    981
    Default extract data from shapefile
    Is it possible to extract data from the data table and create cogo points with that data as the full description?
    Or is there a simple or more effective way of achieving this?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,140
    Default Re: extract data from shapefile
    Are COGO points necessary? You could bring shapefile data in as blocks with the associated data table for each point. Depending on the amount of data, you may run out of room to import all of the data into the full description property of a COGO point.
    2004-06
    Slidell, Louisiana
    981
    yes, cogo points are necessary. it's usually not more than 15 or 20 points and the text string is usually only 4 or 5 short words & numbers.
    I've tried that method but can't figure out how to automatically add the data to the cogo point description upon inserting.
    2002-01
    jUSt Here (a lot)
    9,140
    If you get the data into an attributed block, you can then run data extraction to create a csv file for re-import as cogo points. That is one workflow for you to think about.
    Active Member dotson's Avatar
    2005-01
    56
    Quote Originally Posted by rmk View Post
    Or is there a simply or more effective way of achieving this?
    Since you asked, DotSoft's C3DTools contains a dedicated CogoPoint ShapeFile Import & Export tool. On import. you can easily assign the .DBF fields to primary properties such as description and any remaining fields can be imported as PointUDP so nothing is lost.
    https://www.dotsoft.com/c3dtools.htm
  1. 2013: Import shapes and attached data (shapefile, object data etc) to Revit
    By cooperch663326 in forum Revit Architecture - General
    Last Post: 2014-06-02, 10:53 AM
  2. shapefile edits disappear on Check-In
    By c_rado in forum AutoCAD Map 3D - General
    Last Post: 2007-04-03, 07:54 AM
  3. How do you enable automatic shapefile labling in AutoCAD?
    By sbruzda in forum AutoCAD Map 3D - General
    Last Post: 2006-03-07, 07:03 PM
  4. Export Flood Trace to shapefile
    By kevin.bell81772 in forum AutoCAD Map 3D - General
    Last Post: 2005-08-19, 03:13 PM
