Thread: Breaking Keynotes Up By Sheet
    2008-07
    2
    Default Breaking Keynotes Up By Sheet
    Here's my problem: I have a whole bunch of keynotes all around the project, which are all tied to their respective "condoc" keynote spec number in the keynote txt file. However, whenever I try to create a keynote legend, it includes all the keynotes for the entire project.
    I've tried going into the settings->keynoting dialog box and selecting "by sheet" for the numbering method, but all that does is break my "condoc" numbering system and implement a basic numbered approach (1, 2, 3, 4).
    Is there any way to continue with the condoc numbering system, but somehow filter the keynotes on the legend so that the legend for each sheet only contains the keynotes that are on that sheet? In other words, right now, if I put a keynote legend on the floor plan, it lists keynotes that are on all the other sheets as well---when all I want it to list are the keynotes on that particular sheet. Is this possible?
    Thanks!
    2003-03
    Reno, Nv.
    277
    Default Re: Breaking Keynotes Up By Sheet
    Open up the keynote view...under Legends. Right click, View Properties, click on Filters, check the box Filter by Sheet.
    2008-07
    2
    perfect, that did it. Thanks!!
    2004-02
    Melbourne Victoria AUSTRALIA
    60
    I'm having a similar problem, I have the "Filter by sheet" checkbox checked, but the keynote legend shows every keynote in the project... when I right-click on a keynote that IS NOT on the current sheet and click on "Show...", revit then warns me that it needs to open closed views and it might take some time etc etc - all stuff tht I know, but I'm none the wiser as to why the "filter by sheet" checkbox has no effect.
    BTW, the view is a site plan at 1:200, not that this should be relevant...
    can anyone share any ideas?
    TIA
  1. User Defined Keynotes, Keynote Legend, Keynotes by Sheet (QUESTIONS)
    By prestonljones438185 in forum Revit - Platform
    Last Post: 2013-12-13, 12:30 AM
  2. Reorder Sheet Level Keynotes
    By Cory.Killpack in forum Revit - Platform
    Last Post: 2010-08-13, 06:55 PM
  3. Missing Keynotes on Sheet
    By bpayne in forum Revit Architecture - General
    Last Post: 2010-07-20, 09:01 AM
  4. Revit - Reference Keynotes & Sheet Keynotes on Same Sheet
    By jjsimon in forum Revit - Platform
    Last Post: 2010-06-09, 10:50 PM
  5. Sheet Keynotes
    By libbybapa in forum ACA General
    Last Post: 2008-10-15, 06:59 PM
