Thread: AcRxDynamicLinker failed to load
    2009-02
    Melbourne, Australia
    12
    Default AcRxDynamicLinker failed to load
    Could anyone help me with this problem.
    I recently inherited an AutoCAD customization that is said to be 95% complete through the upgrade from AutoCAD 2005 to AutoCAD 2007.
    This customiztion included an ObjectARX.
    Currently i can only managed to run AutoCAD with the partially complete customization on the laptop of the person who did this work. Any other PC that i use fail to load this an ARX and reports the following error.
    "... Is an invalid ARX file.; error ARXLOAD failed"
    or
    ",,, Is an invalid ARX file. AcRxDynamicLinker failed to load"
    There's various reference to corrupt registry regarding the error "AcRxDynamicLinker failed to load". However i get the same error on a fresh new PC and new installation of AutoCAD 2007.
    I am new to AutoCAD ObjectARX but is there DLL or Reference library that i need to enable the ARX to work? Where can i find these?
    The other problem i have is at this moment i do not have the source code of the ARX. Is there any way to re-verse engineer what this ARX is doing?
    Tony D.
    2009-02
    12
    Default Re: AcRxDynamicLinker failed to load
    I believe this person has similar problem to mine.
    http://discussion.autodesk.com/forum...1495&tstart=60
    Linking to this article
    http://otb.manusoft.com/2007/01/my-m...-manifesto.htm
    It sounds like a solution but i need some one to translate it to English-for-Dummies like myself to understand.
    Tony D.
    Member dmarcotte4's Avatar
    2003-10
    43
    Your problems might be that an Arx compiled for 2005 will not work in 2007 unless it’s recompiled
    2009-02
    12
    Thanks for replying dmarcotte4
    The solution found to be
    In project properties set:
    Configuration Properties->Linker->ManifestFile->Generate Manifest File->No
    Configuration Properties->Manifest Tool->Input and Output->Embed Manifest->No
    tipped off by http://discussion.autodesk.com/forum...sageID=5792752
    This was not mentioned in the ObjectArx guide.
    Anyhow i am happy to have the problem resolved.
    Tony D.
    2009-05
    2
    Smile Re: AcRxDynamicLinker failed to load
    Thanks for this I ran into the same problem and this bit of information was extremely helpful.
  1. Menu Load Failed
    By jkipfer in forum AutoCAD General
    Last Post: 2009-07-29, 04:25 PM
  2. macros load failed
    By a.d.lange in forum Revit - API
    Last Post: 2009-03-04, 11:32 PM
  3. Failed to load MNU - Ye Olde 2004
    By dandlf in forum AutoCAD General
    Last Post: 2009-01-11, 11:33 AM
  4. Failed to load MNU - Ye Olde 2004
    By dandlf in forum AutoCAD CUI Menus
    Last Post: 2009-01-07, 02:00 AM
  5. AcMapWorkspace.arx Load Failed
    By jpaulsen in forum Land Desktop - General
    Last Post: 2006-05-18, 08:31 PM
