Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 46
Thread: RAC2011 -> FBX ->MAX Design 2011 problem
  1. #21
    2004-05
    St. Louis, Missouri
    3,135
    Red face Re: RAC2011 -> FBX ->MAX Design 2011 problem
    Found this out this morning:
    If you have RPCs in your Revit 2011 model, and then export FBX,
    import/link the FBX into 3dsMaxDesign 2011, and no content will show up in the Max scene!
    Solution: Go back to Revit, turn off RPCs, re-export FBX, import FBX into Max,
    and it works.
    I suspect this may be because you need the RPC plug-in from Archvision for 3dsMax 2011? Not sure of availability.
    cheers
  2. #22
    AUGI Addict ws's Avatar
    Ambleside, Lake District, UK
    1,222
    Default Re: RAC2011 -> FBX ->MAX Design 2011 problem
    Thanks, Cliff
    - that's a good one
    I've got the RPC plug-in installed which came with 3dsMD2011 but you seem to also need a license for it at $219 this time around.
    I don't know if it is of any significance but there are rpc_cc.log files appearing in some Revit folders containing the text 'RPC API' revoke licenses
  3. #23
    2004-05
    St. Louis, Missouri
    3,135
    Wink Re: RAC2011 -> FBX ->MAX Design 2011 problem
    Yes-- the Archvision RPC plug-in license most likely needs to be valid, or the RPCs will cause the export/import process to fail.
    Perhaps Autodesk/Archvision can confirm this? This did not seem to happen in RAC 2010
    and 3dsMaxD 2010.
    cheers......
  4. #24
    1,222
    On a related problem,
    once imported into 3dsMD2011 I now get dozens - over a hundred on some projects - objects listed under the error message
    'Warning:Nested Mesh'
    The description is,
    'The plug-in has detected edges that are shared by two or more faces in the same direction.
    the following nodes are affected:'
    .... long list of objects
    Would anyone know what this is about?
    I've not seen this in 3dsMD2010 imports.
  5. #25
    2009-12
    I have the latest FBX plugin for 3ds max design 2011 (2011.2), but max still crashes when I import/ or try to file-link FBX files from revit architecture 2011. Any one know what's happening here?
    Also as anyone got a solution for exporting from revit to .obj files? I have tried using the latest FBX converter to convert to .obj and and that also doesn't work. Just if you're wondering, I want to render the revit model in either 3DS MAx design 2011 or octane render thats why I am trying to convert to FBX and .obj. Thanks.
  6. #26
    2003-05
    East Walpole, MA
    893
    Quote Originally Posted by ws View Post
    The description is,
    I normally get the same thing, to one degree or another. As it hasn't seemed to affect the functioning of Max Design, I haven't bothered to inspect it too closely.
  7. #27
    2003-05
    East Walpole, MA
    893
    Quote Originally Posted by mmaghfai View Post
    Is there a way to convert .sat to .obj ?
  8. #28
    1,222
    Before/after installing fbx 2011.2Have you uninstalled fbx 2011.1 via Control Panel->Uninstall programs?
    That fixed my crashes.
  9. #29
    2003-05
    East Walpole, MA
    893
    I didn't uninstall the .1 version (it's still on my drive), but the .2 version still always fires up without an issue. Also this (which I didn't have the patience to read & comprehend all the way thru...mentioning that it's good practice to keep the old version...just in case...):
    From Autodesk's FBX Help:
    When you install the 3ds Max FBX Plug-in two instances of the plug-in are installed on your computer: the actual FBX plug-in that is saved in the source directory (C:\Program Files\Autodesk\3ds Max 2009\stdplugs) and a copy that is stored in the FBX folder that you specified during the installation.
    The installation screen that specifies a destination folder
    When you uninstall the 3ds Max FBX Plug-in, the process removes only the plug-in copy from the destination folder you specified during the installation. To remove the FBX plug-in completely, you must delete it manually. The reason you must perform a manual deletion is because the FBX plug-in is a part of the default 3ds Max installation.
    Essentially, when you uninstall, you remove the contents of the FBX backup folder, for example, C:\Program Files\Autodesk\FBX\FBXPlugins\2011.1\3ds Max 2009 64-bit, as well as any related entries in the Start menu.
    It is good practice to keep the previous version of the plug-in, especially if you are working on a project where your workflow is heavily dependent upon the plug-in. If the newer version of the plug-in disrupts your process in some way, you can revert to the previous version. If you do not want to lose access to the FBX plug-in that ships with the 3ds Max software, select Yes when asked if you want to accept saving copies of the old plug-in. This option occurs whenever you install newer versions of the FBX plug-ins.
  10. #30
    1,222
    I was a bit puzzled when installing the fbx 2011.2 as it always asks for a destination folder - as it's the 64 bit version I would have thought it would go in the default location - which is where I pointed it anyway.
    Initially I did opt to keep the 2011.1 plug-in and it renames it to .old but eventually manually deleted it, uninstalled it and from then everything worked better - for me at least.
  1. Replies: 0
    Last Post: 2015-08-07, 05:35 PM
  2. Replies: 0
    Last Post: 2015-08-07, 05:29 PM
  3. 3ds Max 2011 Design Installation problem
    By stephen.scott in forum 3ds Max - General
    Last Post: 2010-07-26, 11:06 PM
  4. Design Review 2011 - Installation of Older software problem
    By heath.simone in forum CAD Management - General
    Last Post: 2010-05-11, 04:52 AM
  5. RAC2011 - Problem aligning textures in realistic view and rendering
    By mindauxx in forum Revit Architecture - General
    Last Post: 2010-05-03, 12:21 PM
