Results 1 to 7 of 7
Thread: Sheet set manager text a mix of upper case & lower case
    2007-07
    399
    Default Sheet set manager text a mix of upper case & lower case
    In our set of 100+ drawings the layout names are a mix of upper case & lower case, & it affects the sheet set manager & then the sheet list table when inserted. Is there a way to fix it, ie changing all to upper case in the sheet list table, or would we have to do it manually in the SSM? Thanks.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Default Re: Sheet set manager text a mix of upper case & lower case
    This would be a function of your table style you assign to the Sheet List Table.
    You are looking for the Format option of the General tab for each Cell style you wish to change. Once you click the Format button, a Table Cell Format dialog will display. This dialog will allow you to specify the format for the Text your sheet list will place in the table.
    2015-10
    27
    The sheet title in the table will show up exactly as you have it shown in the SSM, caps or otherwise. The text style, height, and color of the title, headers, and data are controlled by going into the table style manager, and editing the cell styles. The caps issue for the header and title can be tackled by placing the table into your drawing, and then clicking on the header and title fields in the table and replacing the text in them using caps.
    5,779
    Forgive the silly question, as I do not use Sheet List Tables - isn't the resultant Table simply populated with Fields that point to a given Subset, Sheet, or Sheet Set property?
    In which case, Fields can be set to Uppercase, etc. regardless of the case of the original Object's string value (see the Format pane within Field dialog).
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2015-10
    27
    The fields populate the table, yes....but that is only the "data". The headers and title are fixed text, not dependent on the sheet set info. Those are what come in capitalized with small case after, out of the box.
    2002-01
    jUSt Here (a lot)
    9,196
    Quote Originally Posted by cadman1957 View Post
    Although the Sheet Set Manager ignores the predefined cell styles for header / title cells, changing the cell style to the appropriate style would then change the cell to follow the predefined styles. If the format for the styles has not been modified, you would then need to make the appropriate changes.
    2018-03
    I realize this is an old thread, but I was looking on how to change to all caps as well. If you set a text style that is all caps you will get the desired outcome, however, there is a limited selection to choose from though.
  1. force UPPER/lower case in text
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2012-09-13, 02:35 PM
  2. Replies: 3
    Last Post: 2007-01-09, 12:42 PM
  3. Upper/Lower case text
    By djn in forum Revit Architecture - General
    Last Post: 2007-01-05, 10:40 PM
  4. Changing from UPPER case to lower case
    By IamSnave in forum AutoCAD General
    Last Post: 2005-02-09, 10:30 PM
  5. Switch text from Title case to Upper case
    By sbrown in forum Revit Architecture - Wish List
    Last Post: 2005-01-03, 03:40 PM
