Results 1 to 8 of 8
Thread: Acad 2004 compatability
    2008-12
    24
    Default Acad 2004 compatability
    My XP PC is pretty old and subject to hacks and viruses. I would like to replace my PC with a newer one, but it has to be able to run Acad 2004.
    Cairo - no, not Illinois
    5,070
    Default Re: Acad 2004 compatability
    well, good luck with that. Probably not going to be easy.
    Rather than futz around with a decade and a half old version of the software, you might consider trying out the free-to-use-for-any-purpose Draftsight, of the paid version Draftsight Pro.
    Or explore one of the Intellicad versions, BricsCAD or Ares Commander -- all DWG compatible, and cheaper than the rental upgrade from Adesk.
    5,779
    Why not buy a new computer running Win10x64 Enterprise and host your WinXPx86 image in a client Hyper-V VM?
    You've got valid licenses for all of the software you have, the rest comes with the new computer... When you need AutoCAD, just fire up the VM.
    [Edit] - For converting WinXP to VM, here's what you need to know about using Disk2VHD.
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2008-12
    24
    Thank you for your assistance. I'm thinking I may be better off to just use my XP computer as a dedicated Acad machine and get a ne computer for everything else. I'm really not very computer savvy.
    9,831
    Quote Originally Posted by Mr Ron View Post
    As long as the hardware keeps running, you should be alright. Just keep that thing off the Internet
    When it does die, presuming you can not longer make use of the ACAD 2004, I second what @cadtag said and consider getting another perpetual license, of BricsCAD.
    AutoCAD is only available now as a rental, which also may be something to consider if you only use it occasionally. A one month rental is $195.
    5,070
    good info, thx
    5,779
    good info, thx
    You're welcome, gents.
    My Surveyor (VP of the firm) still uses AutoCAD 2000 + Eagle Point daily on his old WinXP box... Even after buying him a schnazzy new workstation, and replacing the legacy box's MOBO following some blown capacitors, he still preferred me to setup a double click + RDP session to his old workstation.
    Porting his physical machine to a virtual machine is the only way to give him what he wants, yet mitigate continuous hardware failures, or necessary hardware components from no longer being available. The only other thing we needed was some USB port redirecting software, that let's his VM be able to communicate with the hardware data collectors, etc from the field crews.
    What kills me, is his x86 CPU + 3 GB RAM can _still_ open his 2000 drawings faster than my x64 CPU + 32 GB RAM can open his 2000 drawing using 2012-2019. Haha
    9,831
    #BLOAT
    FWIW - I have R13 (not 2013, but 1996's "R13") - running on my Win 10 box.
    It's SUPER FAST, as it should be.
  1. Windows Vista - ACAD 2004 with Vista?
    By mrfrancisleung in forum Operating Systems
    Last Post: 2008-02-06, 01:57 PM
  2. ACAD 2007 saving down to ACAD 2004 - ARX Error: eDuplicateKey
    By Dicastaddict1 in forum AutoCAD General
    Last Post: 2006-10-26, 03:35 PM
  3. Acad-A_Title.dwt in Lt 2004
    By heronworks in forum AutoCAD LT - General
    Last Post: 2005-04-28, 02:55 AM
  4. Need to covert 1992 Acad dwgs to present 2004/5 Acad!
    By anapier in forum CAD Management - General
    Last Post: 2005-02-17, 05:51 AM
  5. License mgr. ACAD 2004 & XP Pro.
    By reed.76512 in forum Networks
    Last Post: 2004-10-06, 09:11 PM
