Thread: Hyperlinked Fields in MLEADERS
    2006-04
    Default Hyperlinked Fields in MLEADERS
    Wondering if others have seen this issue.
    Working within a SheetSet in AutoCAD 2018, I have inserted a sheet reference into the text of an MLEADER using a FIELD. The FIELD points to a sheet within the SheetSet and the "Associate hyperlink" options was selected.
    When I publish the SheeSet to PDF from within the SSM, all hyperlinked FIELDS work except those in MLEADERS. "Publish to PDF" is using the AutoCAD PDF (General Documentation).pc3 file.
    This appears to be unique to MLEADERS.
    As I test, I have done the following:
    Within a model file, XREF'd into a Sheet File, I created the following:
    - Hyperlinked Field in an MTEXT entity
    - Hyperlinked Field in a TEXT entity
    - Hyperlinked Field in text of a LEADER
    - Hyperlinked Field in the MTEXT of a QLEADER
    - Hyperlinked Field in Attribute of BLOCK
    - Hyperlinked Field in the MTEXT of an MLEADER
    In all cases, the hyperlinks function in the PDF as expected, except the one in the MLEADER text.
    To rule out an issue with the MLEADER in an XREF vs the PS of the sheet file, placed an MLEADER in PS of the Sheet file --> that hyperlink does not work either
    Have others seen this issue and is there a solution that still allows the use of MLEADERS?
    Thank you
    Portland, OR area
    137
    Default Re: Hyperlinked Fields in MLEADERS
    If you are still having problems: I can't duplicate the issue. I plotted a SS field in an MLeader correctly from the Plot command and the Publish command from within the SSM.
    Do you have all the service packs and updates installed?
    Tallahassee, FL USA
    3,686
  1. Nested hyperlinked drawings
    By jaberwok in forum AutoCAD General
    Last Post: 2015-08-27, 08:12 PM
  2. Synchronizing Annotavie MLeaders
    By jtgb in forum AutoCAD General
    Last Post: 2012-02-01, 03:52 PM
  3. MLeaders
    By marble in forum AutoCAD General
    Last Post: 2007-08-01, 12:16 PM
  4. Replies: 14
    Last Post: 2006-02-27, 11:30 AM
  5. Hyperlinked callouts to autocad
    By Martin P in forum Revit Architecture - Wish List
    Last Post: 2003-07-18, 02:34 PM
