Thread: Changing Line Segment by Custom Tagging
    2013-10
    6
    Post Changing Line Segment by Custom Tagging
    Dear Autocad PID experts,
    I was wondering one issue at this software:
    I created Line segments for each system types and assigned layer/color for each segment.
    i.e: DCW - Domestic Cold Water - Blue
    CHW - Chilled Water - Green
    and etc.
    I was wondering is it possible to change the segment of line on the drawing by using tagging option? (Making custom tagging)
    For example, I draw DCW line which is blue, then i changed mind and decided to change it to CHW line which it supposed to became green?
    Thanks.
    2003-11
    Georgia
    18
    Default Re: Changing Line Segment by Custom Tagging
    Have you looked at P&ID Painter? You should be able to map color by service.
    https://knowledge.autodesk.com/suppo...361A5-htm.html
  1. TAGGING LINE LENGTH
    Last Post: 2017-09-28, 07:03 PM
  2. 2013: Tagging Electrical Circuit Custom Parameters
    By live4ever42 in forum Revit MEP - General
    Last Post: 2015-11-03, 12:00 AM
  3. 2010: making all line segmentsof same line type show as one line segment
    By Darren Allen in forum AutoCAD LT - General
    Last Post: 2015-09-02, 10:35 PM
  4. ACA Custom objects/tagging/scheduling
    By nurbimage731938 in forum ACA General
    Last Post: 2011-08-31, 04:32 PM
  5. problems when changing from custom family to custom family
    By elena.ivanoff in forum Revit Architecture - Families
    Last Post: 2009-09-17, 05:31 AM
