Results 1 to 10 of 10
Thread: Exploded-looking AR-CONC hatch pattern?
    2004-07
    5
    Question Exploded-looking AR-CONC hatch pattern?
    With my Autocad 2005 Map, My AR-CONC hatch looks like it's been exploded, where the triangular shapes are actually "v"s and the dots are too faded. I remember in an earlier version of Autocad, someone in the office had exploded the hatch to modify and create a new pattern and accidentally saved the exploded hatch. The hatch that came with my new autocad had not been tampered with but it looks exploded. I don't know how to get it fixed. Any suggestions would be appreciated. Thanks, Richard
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,196
    Default Re: Exploded-looking AR-CONC hatch pattern?
    Quote Originally Posted by roxford
    Are you working in a large coordinate system? State plane coordinates use a large coordinate systems and sort-of distort hatch patterns. Try changing your ucs origin closer to your geometry and try hatching again.
    13,657
    Hi Richard
    Please note I have *moved* this thread from the Local User Groups Forum to this one as I feel this particular Forum is a more appropriate place for such a topic.
    Thanks, Mike
    Forum Moderator
    13,657
    Hi
    Have a browse of the following thread in the AutoCAD FAQ Forum -
    Hatch patterns playing you up
    Have a good one, Mike
    100 Club murrayc.49304's Avatar
    2003-03
    158
    When I have "exploded" hatch patterns, here's what I do:
    1. Enter SNAPBASE command and pick a new origin point near the "broken" hatch pattern.
    2. Double-click on the pattern so that Hatch Editor dialog box appears, and then just the OK button. The hatch pattern will realign itself.
    3. Then use the MATCHPROP command and match other "broken" hatch patterns to the one you just fixed.
    This prevents you frpom having to rehatch everything as well as going into the Hatch Editor for each pattern.
    2011-08
    2
    Quote Originally Posted by roxford View Post
    It's now June 2014 and I'm experiencing this issue in 2012LT.. why Autodesk hasn't fixed this issue is beyond comprehension. Providing or having a work-around system is ridiculous.
    TN/KY Area
    1,640
    Quote Originally Posted by tim.hodges384339 View Post
    Maybe if you upgraded to the latest version you may see that the issue has been worked on and there is a Hatch Origin variable, should be in 2012 version as well.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,686
    In the ribbon of more current versions you can pick 'Set Origin' or click the 'Origin' drop-down six placement options as well as setting one as the default. With many of us on subscription now remembering when these issues were resolved can be tricky.
    0,0,0 The Origin
    8,570
    or just read and react to post #2.
    Earth
    9,831
    There is nothing to "fix".
    It's the result of rounding errors between the hatch origin and the hatch location.
    Simply ensure that the hatch origin is at the hatch location.
    Having said that, it wouldn't hurt to warn the user if large distances between the origin and hatch were detected.
    R.K. McSwain | CAD Panacea |
  1. 2012: Showing hatch pattern over material cut pattern
    By frqnt in forum Revit - Platform
    Last Post: 2012-11-16, 08:47 AM
  2. Hatch pattern - error in reading pattern file
    By bbapties in forum AutoCAD Customization
    Last Post: 2011-04-01, 11:40 PM
  3. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  4. Turn off conc pattern only in perspective?
    By Maximillian in forum Revit Architecture - General
    Last Post: 2007-04-26, 02:45 AM
  5. Hatch Boundary deletes if Hatch Pattern is deleted
    By Merlin in forum AutoCAD General
    Last Post: 2006-04-23, 01:01 PM
